Discuss LPG Tests in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
Koogatubac
Ok so ive had my LPG for 3/4 of a year now and thats all i seem to do atm, rarely natural gas.
Few questions to see what u guys are doing.
- how are you gas rating appliances? (If you can) Since its a tank not a meter like natural gas
- if your stats on your FGA is reading well, do you accept it regarding your tests
- when your doing your tightness test since its outside im getting alot of waving about due to the wind affecting readings, any easier way?
- after ECV to the property, first thing im doing is cuting a test point in so you dont have to go back and forth to the tank (obv. Making sure the UPSO & OPSO haven't tripped)
Comments always welcome regarding this guys! Doesnt seem theres much LPG gas advice out there.
dont do a lot of lpg, so always having to carry course notes to remind me of what to do. Always surprised to come across combis running off 4 pack bottles, very rich or stupid customers!!!
You can't
Working pressure and FGA
Test it on the gas valve or wear a balaclava or No
Thats sensible
No there isn't
Tamz your on a roll i should just PM you from now on haha!
Lame - yeah im still looking at my course notes however most of it is all about purging than actual tests i thought the course was about
Cheers guys!
nothing wrong with notes i still have a spread sheet in bottom of my tool boxes with maximum readings allowed on appliances etc
You cant go wrong with it lee :) i got a good sheet too regarding purges, gas rate (paper way), fga acceptable readings etc
Reply to LPG Tests in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, looking for some advice on servicing as im a bit behind and tend to take a more holistic approach to it (although im sure thats not...
Hi I've just had my annual maintenance check on my boiler (in title), it will be 8 years old in May this year and is (I think) still under...
2K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi everyone just checking if this is right regarding water pressure and combi boiler pressure: Do hot and cold water always vary in pressure such...
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank...
2K
