Discuss loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Check out their www site they used to give away a sample spool .....regards Turnpin:punk:
Thanks ill have to do that now,
do you all use its instead of ptfe, gas paste... or only on some applications?
thanks
dont think ive ever had a threaded joint leak with 55 not sure its as good as tape on unions like traps and tap cons
Ive never used locktite so im curious to see what fols think aswell, when served my time i was never introduced to it so ive never started,
love it, used ptfe before but since tried loctite, not going back. only use ptfe occasionally on old olives
Good stuff. In a tidy spool. Unlike ptfe which ends up all over the tool bag.
Great stuff I use it for loads of things. I like the liquid ptfe for posh towel rail and cast iron radiator unions. Expensive at £15 a tub though.
Great stuff, the big spools last for ages and can be had cheaply from flea bay. Also nice you can back off quite a bit and not worry about leaks.
Only problem i have with it is that you cant use it on oil
I'm a fan of it too.
I find you can undo the joint a bit if you've overwound it withoput it leaking.
Loctite 55 is the business get your free sample from the link below
[DLMURL="http://www.loctite55.co.uk/index.php?FOLDERID=18078&"]Henkel Loctite - Loctite 55 - Request a sample[/DLMURL]
Not something I use on a daily basis but definitely very handy
Great stuff, used it 15yrs or so back, only one problem that I recall and that is you can`t see how much is left in the tub.
can also be used as floss - if youve got big gaps
I said that to the rep at PHEX last year, he winked and said they can't advertise that in case someone floods a castle or something!
your paying way too much.
going rate is about 8quid for a 50metre spool round here. but i get it for 2 quid as a local indy bought a load and cant shift it....
Its good tack. My old boss back home used to make us use flax/hemp and boss white nothing else. Its good stuff
Great stuff, never had a leak with it.
The only thing I would change would be to make the lid easier to remove, its a pain in the bum if you lose the thread and have to get the lid off.
Thanks for all your replies, just got my free sample just need to try it out now
arrived today, cheers mate. Can't argue with a freebie
According to loctite you can? But then again they say it ran successful on steam test. They didn't see my test lol.
Reply to loctite 55 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
To repack a stop tap gland with loctite 55. Are you best having the stop tap open before you back the gland off to repack? I have always done it...
Deleted member 120897
Got some quotes for a service, one person has said if I haven't had the burner seal replaced for past 5 years, it should be done (& service price...
WB 4000 installed a few months back, just balanced the 7 rads - managed to get around 15 degrees delta across most rads. Not quite the 20 degrees...
C
I’ve had an Ideal Vogue 32max/gen2 system boiler to a Megaflo fitted a week and running it at Flow temp 73 degrees to getting a return temp of...
Hi everyone, I'm hoping to get some advice on an issue I'm having with my Vaillant Ecotec Pro 24 boiler (R1 PCB). It was installed in 2013 and has...
