Discuss Leaving ball-a-fix valves under tiled floor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Dannypipe
Subscribed
Hello all. I haven't been here on here in ages. It's very interesting reading all the different threads, and realising we all have the same ups and downs!
Anyway, while I'm here, I thought I'd ask a question.
I'm working for a builder this week, in a large house that has another firm + plumber doing a loft extension.
I'm first fixing a bathroom suite that I ripped out today. The other plumber drained the c/h system and I moved my pipes to the rough position I'll want them, but as the towel rail doesn't arrive for a week, I just capped off with 2 full flow ballafix valves. That way I don't have to drain the system, refill, inhibitor and vent. Anyway, the other plumber refilled the system (Saved me a job) and I just want to be lazy and plumb away from my Ballafix valves when the rad arrives.
What troubles me, is that ply and tiles will cover these valves one day.
They'll only ever get turned on/off once and we all use compression fittings without issue, so am I being paranoid? Or should I spend the considerable time and money doing a full drain down etc?
If you do reply to this, many thanks,
Dan
i would love to tell you no, it shouldnt be done, but ive done it myself - so wont.
chill out. xx
chill out. xx
That's what I wanted to hear mate! Cheers.
I guess I worked with my old man too long, he'd make me whip em out!!
seen and repaired more speedfit underfloors than ballofix.
smear some lsx around them to be sure.
dont forget to move house in 2 years so you dont get a call back when they do leak
Two years isn't very optimistic!!
They should be fine. I deserve some good karma, but lets face it. If I got a call out and found a leaky ballafix under a tiled floor........after I'd ripped a hole in the ceiling and repaired it, I'd say 'what a cowboy'!!
Ha!!! - But the general concensus is they'll be fine, and think of all the money I'm saving my client. Finally, I know it's been done before, as I've seen it, and no they haven't leaked. I just wondered if it was a MAJOR no no.
went to a callout recently where the ballofix valve had shut itself down over time and the taps no longer worked inthe kitchen that is until me and my screwdriver arrived. I think you said yourself, its a cowboys trick and isnt very professional
no compression joint should be buried its bound to get a prob at some point
is that another one of your own rules newbie?
do you have an idea to the amount of compression joints under floorboards in britain that dont cause problems - nope because you only know about the ones you have to fix.
do you know how many soldered fittings there are under floorboards - nope because you only know about the ones you have to fix.
very bland comment, and no proof.
Those slotted ballofix valves tend to leak from the slot when you try and turn them off after a couple of years, no ones going to be doing that, "theyl be reet".:)
If you're so worried, why not freeze the pipes and whip them off when you're doing the installation? A throw away kit costs around a tenner and I've not had any problems with them.
Reply to Leaving ball-a-fix valves under tiled floor. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
