Discuss Leaking valve?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scopas
Hi
I have a leaking valve. Can anyone tell me what this valve is and what it's for? Do they break often? Do I need to tighten or replace it??! Thanks guys
Replace sorry to say
Also anything to do with an unvented cylinder needs a person who holds there G3 qualification
Hi.
They split inside , I'm afraid. So it's a replacement.
To cover your household insurace, and legality, you will need a local plumber who is G3 registered to do this.
I will be a quick job. And he will make sure it's compatable with your cylinder.
While he/she is doing the replacement, ask them to service the cylinder.
Hi.
Thanks just to clarify is G3 for gas? There's no gas on site just electric. Happy to get an expert in..
G3 is a qualification for pressurised/ gravity hot water cylinders
G3 is a qualification to work in unvented systems. Most gas safe, are also G3 qualified
G3 to work on unvented cylinder. Leak will be from join between two parts of black plastic, common fault with heatre combination valve.
[DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
Or here.
Or here.
Reply to Leaking valve?! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
Hi all. This ‘valve’ is at the bottom of our domestic hot water cylinder. Anyone have any idea what it is please? It must’ve been there for many...
Hi I have a leaking TRV on a downstairs radiator and need to get it replaced/fixed. Can anyone on here tell me the average cost to have this done...
Good evening, I'd like your opinion on something that is worrying me please: my landlady's plumber replaced the bottom/night element of my...
Hi all, need someone to do my annual gas service and issue me a domestic gas safety certificate. In addition the megaflow cylinder needs checking...
