Discuss Leaking tap fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
floody
Dear all,
Anyone have any ideas on how to fix a leaking tap (image attached)
Something i could do myself (absolutely no plumbing experience) or would i need a pro to look at it.
Thanks in advance.
Sorry its a Danish brand :/ this is all i could find.
Its Toni SP Kitchen tap with 200mm spout.
Cant find any details on your tap You could contact the place where you purchased it and might be able to download a parts list for spare parts.
Reply to Leaking tap fix in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello folks, I’m trying to fix this slow leaking tap myself and I’m stuck here. How do I dismantle it further to replace whatever needs replacing...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Please can someone advise how to fix this shower that leaks? I guess I need to replace the washers inside the taps. Is it the blue or red one? My...
hi all, i need help to fix the leak from a pipe connected to the water pump via flexi pipe and it is feed from the immersion heater. I have...
hi i have a drip leak from the bottom of this pipe see attached how do i fix it is there a video that would help me cheers
