Discuss Leak from Isolator valve tap connector nut on bottom fill cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All,
I was trying to replace a failing fill valve in my cistern, I got the old one out no problem, adjusted the new one, popped it in - carefully hand-tightened the nut - and as per the instructions - let the water back in to check the seal. It leaks (sprays) from the bottom of the metal nut that joins onto the plastic threaded cistern valve.
The metal nut at the top of the isolator valve still has some play (relative to the valve) after it's finger tight on the plastic thread. That can't be right surely?
A few questions:
I'm pretty sure I haven't cross threaded it - but how can I be certain?
Do I need to replace the fibre washer? Should the fibre washer push right down inside the nut - or sit just inside it on the threads?
There's a link to a picture - with some arrows to show where the water sprays from. (before you point out that it's wonky - when I took the photo it was just quickly attached to the old fill valve - as I was fiddling about and didn't want to damage the plastic thread on the new valve).
All advice gratefully received.
Welcome to the forums Stytagm clear out any old bits of the old washer and renew...it should sit low down inside the fitting over the shoulder that will fit inside the threaded part of the fill valve and the nut must move freely hope this helps ...regards Turnpin:)
Evening mate, whenever changing an inlet valve you should always change the fibre washer as a matter of good practice. The nut should easily tighten on that thread with no loose movement, especially with a new washer and as you've already pointed out, as long as it's not cross threaded it won't leak.
Good luck
you will know if you have crossed threaded it either see the threads split / bugged or go very tight
either a new fibre washer or rubber o ring should sort you out
(dont forget the retaining cistern nut also) :)
Thanks everyone - I'll grab a new fibre washer as soon as the shops open tomorrow. Could anyone eyeball it enough to guess what size washer I want? And is b-and-q OK? I could also get to screwfix or toolstation easily enough.
PS - ShaunCorbs - yes I forgot the retaining nut when I took the photo - I'll remember tomorrow :)
Not a fan of them service valves. Also more liable to have issues with plastic to metal. If cross threaded I take my grinder and chop a bit of the plastic off. Not an exact science though.
Best solution is to fit a fill valve with a brass shank. Plenty of paste on the service valve and washer.
15mm fibre washer matey, b and q, screwfix, toolstation or any good merchant, although no merchants will be open sunday
Agreed, I install hydroflo valves with the brass shank, however, no paste as it could get lodged inside the valve. If you fit a new fibre washer correctly there should be no need for paste and it won't leak
Thanks again everyone. OK - One last thing. Is a 15mm washer a 1/2" washer? I can't find any 15mm ones listed on the major DIY/builder's merchant websites.
A link from either Toolstation or Screwfix would be super useful (they open earlier on a Sunday)
A metal nut on plastic thread is a defect waiting to happen. Trying to tighten on a fibre washer makes failure more certain. This is why fill valves with brass shanks have come back in fashion. If you must use a brass nut make sure you're using one with a soft rubber O ring, so seal can be achieved without over tightening nut on thread.
Reply to Leak from Isolator valve tap connector nut on bottom fill cistern in the Plumbing Jobs | The Job-board area at PlumbersForums.net
