Discuss Ladders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
JAH HEATING
After a set that can get us up to gutter, ones that fold up an can fit in back of van no probs..
somebody said Costco ain't bad ?
any suggestions lads ?
Can use class 2 as well BS EN 131 suitable for trade use.
Toolstation do a set made by abru look up to the job treble 2.41mtrs for £119
class 1 are the best but heavy (28kg as opposed to 18kg ) and IMO overkill for occasional use.
Easidec ladders spurs are brilliant as well. £89 but well worth it, you can walk up the ladder about 1.5mtrs with it being away from the wall without it toppling and they adjust easy to uneven ground.
all the ladder accidents i have seen are with class 2 or cheap tat, buy the best as its your neck on the line
I've got a transit, but I will be downsizing soon to be honest when I go offshore.
i was thinking along the lines of maybe the fold up ladders you can fit in the back easy ?
they will only be getting used to patch around flues on upstairs boilers an any condense pipe work high up
Class 2 are suitable for up to 150kg. Ladder accidents happen due to idiots putting them up wrong or using damaged equipment, not because they are not industrial grade ladders. More accidents probably occur because people use class 1 ladders and forget about the fundamentals when using them, they can still slip and still need to be put up correctly regardless of the extra 25kg rating. Carting them on and off the roof rack and safely erecting them also plays a part which is where the 10kg weight saving can help. None of my class 2 ladders bounce much, although they do a bit more than class 1 but its nothing worth worrying about.
all ladders are only intended for short work duration, getting up onto the roof to drop a flue in, or sealing the flue and soldering a PRV on etc. any more than that and should be questioning whether a ladder is the access correct method anyway.
each to their own of course, use what you want but don't try and make out that a class 2 ladder is unsafe in itself as it is untrue.
i don't think they make fold up ladders big enough for that, they normally only extend to 2.5 - 3 mtrs. Personally I wouldn't feel safe on them that high (class 1 or not) I've had a few sets over the years and they are clumsy to put up and there's is no way of checking the locking mechanism as it's all internal to the frame.
Reply to Ladders in the Plumbing Jobs | The Job-board area at PlumbersForums.net
