Discuss Knocking Worcester Bosch Greenstar Heatslave 18/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Patch1977
I have recently exchanged a failed boiler for the WB Greenstar Heatslve 18/25, which was basically a like for like swap. The failed boiler was the same model, albeit 10 years old.
As the boiler stops burning there is a clunk/knock. Sometimes it's quiet, sometimes loud.
The pipework was altered for the install but not majorly.
Can anyone give me any clues? It works fine.
Thanks!
Ring Worcester its under warranty if youre sure its the boiler.
Installer would be the first port of call though. If threis is the mk2 version they may have problems with them as they are new out
Reply to Knocking Worcester Bosch Greenstar Heatslave 18/25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
