Discuss Kitchen Mixer taps dripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Posted in the shower forum and the advice I got was excellent so hoping it's the same for my tap problem
I have mixer taps in the kitchen which had a drip now is a small constant flow of water.
I've tried undoing the stem and pulling it out and there is no chance it will come out.
I was advised that it would be the washers on the on/off handles
I've undone the screws and removed the handles and taken of the cover to show the nuts to undo, I cant get them loose, there so tight. There that tight I'm scared off snapping the tap.
Is this normal or I'm I doing something wrong.
Thanks in advance
sorry
hope this helps
End caps unscrew where the h and c are normally
I can get the end caps off but cant undo the nuts to remove the section that holds the washer I need to change
The chrome outer shrouds ?
If so strap wrench is your best bet the rubber ones
I can get the chrome outer shrouds off too
The nuts underneath the shrouds are so tight. even sprayed with a release agent but still no movement.
I was on one spanner and my son was on another so we could try and undo them at the same time to keep the tap from bending but still they wouldn't come loose
I get you now
You need a bit of force to undo them as there prob scaled in you can't hold the spout either as that would damage it
Only thing I can suggest is either change the tap
Get a plumber out to change the cartridges
Or give it one last try and give it some welly while trying to hold against
I find a socket and wrench and if it won't budge then try tightening it and then the other way. Its as much force as you dare put on while trying to keep the tap from bending the sink.
They're ceramic disk cartridges. If you're lucky there's a couple of the more common ones on sale in most merchants and sheds. If you're not lucky then you'll need to do a lot of digging to find the right ones or there is a way to make the right ones with a kit some plumbers have (Made in Yorkshire by someone called Dave:) )
Reply to Kitchen Mixer taps dripping in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
