Discuss Is my flow adequate? What should I expect? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi all,
first post so go easy,
looking for a bit of advice please.
I have approx. 18L/ minute flow rate mains at the stopcock with 2 bar pressure.
worcester Combi boiler approx 28kw, downstairs shower gives 7 L / min without showerhead and no other hot taps on. can’t turn on two hot taps at the same time without one completely stopping elsewhere.
just moved in and don’t know when Combi was last serviced, would you expect better flow for the shower? I think it’s a little weak, and feels weak when showering.
Any reasons for why it may be low? Heat exchanger etc?
what potential remedies could I try?
thanks advance,
Reply to Is my flow adequate? What should I expect? in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
