M
mrashton
I noticed the isolator in the Red box in this photo is leaking at the top nut (sorry about the blurred view). This isolator is after the water meter on the cold water mains inlet to my flat. I was hoping a simple tightening of the nut in the Yellow box would suffice but now I am not so sure. I asume the top end of the isolator valve is a swivel (as opposed to the bottom that will be a compression fitting with an olive) and as such probably has a fibre or rubber washer that will need replacing.
I would appreciate help in identifying the part and manufacturer so I can look at the technical diagram and hopefully work out what type of seal I need before unscrewing the nut and possibly making the situation worse.
Thanks.,
Matthew
Thanks.,
Matthew
