Discuss Identification help please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AF1QipPXrRI6gNmEOjZx0wJTD3nsScRRjyW3GRBWlwVm
Hi All
Could anybody identify this for me please ( the silver box), it's on a santon premier plus pp210b calorifier, is it a pump?
Andy
8tJ4lE_NCgNHF-_Znorbkmlem46YYQuJ5lpwap-m19qb4fjOIPaGMSWINEmJUCABWUjIZmehiFcky7vljdkHshLthnK6SalDtxVDhcPMfizZ3YYaPNBqQTunL81xz1cJHMFPHEoJbxgU48-sw0pUxbQWGlrXc78R1xdq3IRiz1RcJt-0kkU75A-sJ7VP66RN34FBgFZcuKQsgp6StFAj93DLdFpRU8jpFWznbYpI2nt4R3JVX3ZQ9yaWtdm5qGAswR0tgH0r4362RTwAVvMLkB77aWSeQDoXW2-n3UI0r3Q1pcn5QArYbUTPQYRiDMd7LaBERYXhzdHG1QzT8tNwyVLU_3C-37YQooaiVOOeJZI9nLaiTgARCS6R8kkHs1fVk-CWkH9O8C_5jOmkXekg9BwAchlwicgld6xssgiggaRCaFMr8TXPslFpr44ccU8ilEFLu47Oqix2OSgDQrlUeXY7mb-ubvhVA0FuCgaS4qA_X7TOF_F_a7basdpn4gsECxXL3hEovoCaiRXhbMtnv58m0JB9TlSo16pvKrVxQNqILZNVy_q62lJKuhyWvfZukGTh__r7cvHDlUv5T6mNgp7SISkwnmENRAKPn7R7o9DUkYnFC63-M0PqvpZDw2VBk5gWXXME8thlCEdS0FWB1rwzWhnyr5sC=w481-h641-no
3 port valve
Thanks just googled it and i understand what it is now, am i right in thinking on this boiler it would be sending water to the boiler and then two or one other places such as hot water and hot water for heating
whats the fault / wrong?
Nothing Shaun, i'm starting out in risk assesment and looking at water heaters and trying to learn as much as i can by self tuition,cheers
do you see anything wrong might not be your job tho so dont know ?
So what can you see that’s wrong with it? I think I’ve spotted a couple of issues
1. As others have said, its a 3 port motorised valve.
2. If the controls call for hot water, it will divert the hot water from the boiler to the coil within your unvented hot water cylinder.
3. If the controls call for heating, it will divert the boiler's hot water to the space heating system (radiators and / or underfloor heating).
4. If the controls call for hot water and heating, it will send part of the boiler's hot water to each.
5. I don't like 3 port valves on unvented cylinders, as they may not cut the supply of hot water to the coil off. I prefer to see two 2 port valves, or an additional 2 port valve for the cylinder.
Is that vented or unvented?
That's a lovely place to put a drain off smack bang above the electrics :D
You’ve given the answer away.
It’s not a case of liking a three port on unvented it’s not to regs full stop.
Thread closed too dodgy on unvented front
Reply to Identification help please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
