Discuss Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon all I was just wandering if the Ideal logic + heat 18 has a build in frost stat.
No they don't best to fit an external one, only problem is you need to be gas safe
No its not insulated. The boiler is in the garage. The garage is a new build. So not likely to get cold in there. But iv heard it's always best to have a frost stat if the boiler is outside the house.
Might invalidate the warranty on the boiler if you do not have one.
Ok great stuff. Just out of interest is the boiler in danger of not working if the garage gets a little chilly in the winter. Not Frezzing just cold.
How do you know it wont get to freezing temps?
Obviously you are wasting heat through non insulated pipes
As above, but I would get someone in to quote you before you decide it is a definite NO.
Only say it won't be Frezzing in there as it's a well insulated garage. Sorry the pipes going into the boiler are Insulated but the gas pipe is not. All this is in the garage. Hope that makes sense.
Sorry not read all above , you dont just insulate pipes to prevent freezing its also to prevent heat loss .
Ok thanks for advice. Only asked original question. As someone on the Web said it had a built in frost stat. And as they could not see an electrical connection for the cable.
Reply to Ideal logic + Heat 18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got fd code on Ideal Logic Heat 15. Had two plumbers out and no joy. It’s had a new water flow sensor, flush with sentinel x800 and refurbished grundfos water pump. Boiler tries to light and water pump power light comes on but goes off immediately and boiler flashes fd again. It’s heat only so I...
Has anyone else come across this situation? I keep detecting products of combustion inside the casing of Ideal Logic boilers. I've replaced every seal I can find, namely flue seals, turret seals, sump connection seals, burner seal, electrode seal, flame detection seal, etc, and yet still I pick...
Ideal logic heat 18. Uncoded intermittent fault near end of days use only. Burner reignites every 15 seconds on and off, but no fault code showing. Boiler isolated and restarted okay but same uncoded fault repeated at end of next day.
Does anyone know of a weather compensation unit that can be fitted to a cylinder? I have an Ideal Logic Max H24 which heats a thermal store. The boiler can take an Ideal weather compensation unit to raise the target flow temperature as the outside temperature drops, but the store temperature...
