J
jen0dorf
Hi
firstly I'm not looking to fix the boiler but I do think I need advice as to how the boiler works as I seem to be in the middle of a three corner fight.
I had a new boiler fitted only three weeks ago and it all worked well.
Couple of days ago was a bit chilly so I put the heating on but the radiators were cold.
I checked the pressure - technical I know and it was low so I followed the instructions and re pressurized the unit.
However still no heating.
Ok I have a Honeywell CM 727 control unit so I set the temperature control to 30 - the flame indicator came on on the radio control unit.
I looked at the boiler and it was saying c and the blue burner light was on - hip hip hooray- after three mins the blue burner light went out and never came on again but the c ( for central heating) was still on and I can here what I assume is a pump running.
If I turn the hot tap on hot water comes out and the blue burner light says on until the tap is turned off.
Sorry to be so long winded.
Ok I phoned Ideal who would not put me through to any support but told me it was the thermostat - which I can't see because the boiler is clearly receiving the signal to start heating up.
Spoke to Honeywell who say it's a boiler fault and I will see the c in the window all the time when winter is selected - which is not what it says in the manual.
So finally to my question - who to I go to the installer, Ideal warranty service or Honeywell?
Would appreciate any advice
many thanks
Ian
many thanks
Ian
