Discuss Ideal logic + combi 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sorry, here you go
And the magnacleanse valve is definitely open and not blocked. Easy way to tell would be loosen the magnclean valve nut at the bottom and move slightly off the olive. I've had those snap internally... Though that was on the old ones to be fair.
I pulled the magna clean pushfit fittings off and checked to see the valve open and close
Arnt them valves on the boiler closed I’ve had a few where the handles round and don’t do anything
Think you said you'd already done few bits of this but I'd approach that job in following way.
First walk the system and see if there's any valves on the ch circuit anywhere that could of been switched off in error (sometimes where it was a conventional boiler with cylinder in airing cupboard valves get left in e.g. Summer valve)
From there I'd drain the boiler and remove the 2 isolation valves and ensure they are 100% opening and that they opening all the way.
Then I'd follow the magnclean valves the same which again I think you've done.
If possible to identify last rad on return to boiler. Isolate and drain. Then attach hose or just into a rubble bag open the return side valve and see if you get the correct flow of water coming out. If yes then the fault definitely lies between the magnclean valve point and the return of the last rad.
Once identified there's a few options.
With system drained connect into the pipe at magnaclean pipe with a 22mm compression fitting (in place of the bottom magnaclean valve) going down to an 8mm copper pipe (or appropriate fitting made up to fit a footpump up to... 8mm pipe works perfect if you've got some.)
Then pump up the pressure and it can clear by pumping up to a high pressure. Obviously there is a risk with this... But generally the risk is a joint popping and needing re-piping. . But that's one of the other options anyway so I'd try this first after checking all accessible sections of pipework.
What about the return filter in the boiler ?
This post beggars belief, unless I have missed something, no water is getting through the magna clean valve. ,!!!!! Start there .
Both magna clean isolation valves do open...... the pictures shows the top valve closed, when opened water be flows out of the magna clean, the bottom valve is in the open position and actually opened but no water flows out.... I have checked it with the magna cleaned removed ....
Hey did they come out yet? Could the diverted body inside be jammed to dhw? Therefore stopping flow round heating circuit?
I was thinking that but I removed the DV motor and manually pushed in the pin fully but still no different....... the customer is not prepared to call out Ideal so we may never know?????
Reply to Ideal logic + combi 30 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
