Discuss IDEAL LOGIC COMBI 30, hot water not very hot in the USA area at PlumbersForums.net
IDEAL LOGIC COMBI 30, hot water not very hot, water flow fine. Would I be right in that the diverter valve cartridge needs replacing. Any other suggestions
Can we have some more information please is this a recent occurrence how old is the boiler is there a filter fitted a picture of the boiler would help ?( Your boiler will only raise the cold incoming temperature by 35 degrees the recent cold snap could quite easily have lowered it to 2-3 degrees does the water get hotter if you slow the tap flow down ? Does the boiler go on then off repeatedly when the hot tap is turned on ? Regards kop
Thanks for the reply,
Additional details as follows
Boiler age about 8 yrs, flow is good, the problem has been with us for about 2 months, boiler stays on continuously not cycling, water temperature is 38c
I have reduced the flow rate but no difference
Regards
Is this all taps / outlets or just a couple?
Reply to IDEAL LOGIC COMBI 30, hot water not very hot in the USA area at PlumbersForums.net
