Discuss Ideal Icos HE18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Northern Monkey
Hi All,
Seem to have a bit of a problem with my central heating system. All was working fine this morning. Now I only seem to have heating upstairs. Hot water is fine.
Read through manual, and a lot of the other posts on here, oh deep joy! Think I have just found the catch to Warm Front.
I have the flashing burner light, but for the life of me I can't see an LED panel which gives the fault codes. Have tried the reset button, which seems to have worked a couple of times and tried the off/on thing a couple of times. It seems to fire up, but downstairs is still freezing.
Any clues before I have to try and do battle with Warm Front tomorrow please??
I'd second that. I was always taught if the upstairs rads work and downstairs dont its the pump and if the other way round then its the ball valve. Could try bleeding your rads first though. Or maybe get a new boiler as this will probably be the first of many faults you may see. Sorry to be the bearer of bad news but your boiler is tat.
Thanks for the advice guys. Not so sure about the axe though!
Did think the pump might be an issue, have been bleeding the rads also, taken a good couple of litres of water out of the downstairs ones so far. Is this enough, or should I carry on, keep my fingers crossed and pray to all known gods?
With regards to the pump, I can see where the connections to fix the pump onto the system. Daft question for you, is this 'wet'. In other words do I need to mess around with the water, or can I just unplug the front thing and change it over myself? No issues with the electric bit, just can't work with water, always seems to go wrong!
Reply to Ideal Icos HE18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got fd code on Ideal Logic Heat 15. Had two plumbers out and no joy. It’s had a new water flow sensor, flush with sentinel x800 and refurbished...
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
Hi I have a Vokera 15 vhe boiler and all has been running well for the last 6 months since moving in up until a few weeks a go. Boiler throws up...
M
Hello - I have a Ideal 35kw combi gas boiler. Everything was fine until I switched the heating on for the first time this year. Then I got a L2...
Hi all I have a Vaillant eco boiler at a new house I moved into last week. It’s a combo boiler and the last boiler I had was old (and much...
