Discuss Ideal Icos HE18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
Northern Monkey
Hi All,
Seem to have a bit of a problem with my central heating system. All was working fine this morning. Now I only seem to have heating upstairs. Hot water is fine.
Read through manual, and a lot of the other posts on here, oh deep joy! Think I have just found the catch to Warm Front.
I have the flashing burner light, but for the life of me I can't see an LED panel which gives the fault codes. Have tried the reset button, which seems to have worked a couple of times and tried the off/on thing a couple of times. It seems to fire up, but downstairs is still freezing.
Any clues before I have to try and do battle with Warm Front tomorrow please??
I'd second that. I was always taught if the upstairs rads work and downstairs dont its the pump and if the other way round then its the ball valve. Could try bleeding your rads first though. Or maybe get a new boiler as this will probably be the first of many faults you may see. Sorry to be the bearer of bad news but your boiler is tat.
Thanks for the advice guys. Not so sure about the axe though!
Did think the pump might be an issue, have been bleeding the rads also, taken a good couple of litres of water out of the downstairs ones so far. Is this enough, or should I carry on, keep my fingers crossed and pray to all known gods?
With regards to the pump, I can see where the connections to fix the pump onto the system. Daft question for you, is this 'wet'. In other words do I need to mess around with the water, or can I just unplug the front thing and change it over myself? No issues with the electric bit, just can't work with water, always seems to go wrong!
Reply to Ideal Icos HE18 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Sonya K
