Discuss Ideal DHW turbine leaks how many . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
As the above how many have you lot repaired as it seems as the all leak I have done loads including many I have fitted
yep
I've done quite a few and had no leaks.
Drain down dhw circuit, vac as remove & when turbine is out I vac out the orifice for new turbine.
Run finger around where new turbine will go to check for sharp edges.
Little bit of silicone grease on seal & gently wind in taking care of seal.
Nip up & restore water, run cold through taps till free of air & turn boiler on & test with boiler heating the water as normal.
Job done.
Yep I have done a few and had no problems , “ kiss of death” that !!
Reply to Ideal DHW turbine leaks how many . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
Hi all Noticed bad smell in my drain out side put my hand down and it unclogged it for now however I checked my sewer drain and after flushing my...
