Discuss I am trying to swap the stopcock as it just keeps turning when trying to turn off the water. There is a grey thing on top I'm not sure what it is? in the USA area at PlumbersForums.net
Hi, I am trying to swap the stopcock as it just keeps turning when trying to turn off the water. There is a grey thing on top I'm not sure what it is?
Pressure reducing valve
the stop tap will take a good 10-15 turns (clockwise) to close
Might take a good minute to stop running
Turned the water off on the road and all taps go off apart from kitchen. Slows the flow but doesn't go off after running for 30mins. Any ideas to why this is? We have a pressure system on the middle floor. No tank in the loft. Thanks.
Sounds like outside isn’t shut off completely, or letting by. Is it enough to do what you want to do?
Time to phone the water board as it’s there stop tap tell them it’s not turning off
You can’t turn it off and your internal one is leaking so need replacing so you need it off ;)
Reply to I am trying to swap the stopcock as it just keeps turning when trying to turn off the water. There is a grey thing on top I'm not sure what it is? in the USA area at PlumbersForums.net
Hi everyone, I've joined the forum today as I've found myself going round in circles with what I think might be a pretty simple problem, hoping...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi all, thank you so much in advance for any help. I’m always really grateful for the advice and support from experts when I have been on here a...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked...
