Discuss Hydro block pin hole worcester in the Gas Engineers Forum area at PlumbersForums.net
Tommo25
Went to look at a leaking worcester combi 30cdi, and found it has a pinhole/hairline crack in the flow unit hydro block. (LHS bolts onto plate to plate heat ex)
Any tips or anything I should look out for when replacing the flow unit (87161063560) I don't do too much work on Worcester boilers but it didn't look to bad to replace. Also with the current climate cant be to picky with work
Thanks in advance, stay safe
Easy to do just need silicon grease makes putting together easy
All seals come with it normally sell fitting a shock arrestor at the same time
As others have said it's not a bad repair to do, unlike the right hand manifold. Had two of them go when we've been on lockdown - and usually I hardly have any go! It's easier getting Worcester to do their fixed price repair for that one.
Thanks everyone job done, after dhs sent the wrong part some baxi electrodes (not even close). Luckily city had one on the shelf, heating and hot water back on. Happy customer, and not too bad of a job at all, a lot easier than it looks 👍
Reply to Hydro block pin hole worcester in the Gas Engineers Forum area at PlumbersForums.net
Hi everyone, I have an issue with my bathroom sink. It's been "blocking" regularly, maybe once a month, for at least 3 years. The sink fills with...
3K
    • Funny
My first post, so apologies for any incorrect terminology I had a Bosch Worcester 30CDi Greenstar Classic Regular Boiler installed in 2014. The...
10K
Mrloaf
M
  • Locked
​Hi our worcester 30cdi is causing us much confusion. A while ago the temp in the shower started fluctuating this got worse until the water got...
2K
Dotty
C
  • Locked
Hi ladies/gents, I'm new to the forum. I'm after a bit of advice regarding my situation. I'm trying to pick the best option for repairing a...
4K
cammy0102
C
R
  • Locked
Hey all, apologies for the long post: I've had a new Ideal Vogue boiler installed with a T6 wired thermostat so the OpenTherm is activated as...
4K
richardc1983
R
