Discuss how to replace a hot water cylinder with a combi bolier in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lukev1
hi i am a apprentice plumber and i am on a trial run with a gas registered plumber and we will be replacing a hot water cylinder with a combi boiler and i wanted to know how this is done so i have some knowledge for when we do the job on Monday. can anyone help?????
isnt this the reason your working with someone as an apprentice? go learn on Monday, if you start telling a potential employer how and why you wont get any jobs, but if you go and fetch and carry quickly and leave your bloody mobile at home you might get back on tuesday.
As above, keep your phone in your pocket and on silent too. Break times be the last to sit down and first to stand up ready to get on. And never, and I mean never interrupt pop master
I think an apprentice that does there homework is just as good as a dog
Basically you get ch pipes from wherever you can and the hot and cold. You chop out all the gear you don't use. You probably get sent in loft to strip out tanks.
1 make sure they are dry
2 ensure you know what each pipe is before you remove as you may find that there is a balanced cold from the cwsc to main bathroom bath / shower
Everyone has said most things, listen to what you are told, try to help the best you can and so interest in what you are doing.
Good luck :)
All of the above. Plus if you think there's nothing to do, tidy up.
And treat every home with the respect you would like your home treated. I once caught a love slave jumping up and down on a bed while removing a box section. He left the job by the scruff of his neck.
And also as said before. Never. Ever. EVER interrupt pop master. Such occurrences result in indescribably intense agony......
If you want to understand how to change systems then the best way is to look at diagrams and layouts of each different system as you need to understand the functions of each system b4 you learn how to change them so look at some books b4 job,,,
Hi there you want to take all the guys advise Kris's advice was particularly good study schematics etc.Dont try and tell plumber how to do his job(ive had this before) he will probably work in a totally different way that you've been taught.
DONT try too hard this can cause accidents.All the best bud let us know how you get on.
Reply to how to replace a hot water cylinder with a combi bolier in the Plumbing Jobs | The Job-board area at PlumbersForums.net
