Discuss How to fix leak after installing new kitchen tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently installed a new kitchen tap, installation went smoothly until tightening the second flex pipe onto the existing pipework when tightening the whole section just started to spin round. It spins in either direction with no direction seeming to tighten anything, not loose enough to turn by hand mind you. Now when the water is turned on water pours out of the bottom of the fixing. Looking for advice on how to fix as this was supposed to be an easy job and cant turn water on in house until this is fixed because the isolator has siezed and had to turn off the stopcock to attempt this job in the first place, thanks in advanced for any help (pic attached in case my description is lacking)
All of that need to be removed and put 2 x 15mm full bore isolation valve on the pipes then a new small piece of 15mm pipe and then 2 x 15mm x 1/2 compression couplers.
Errm sorry Wayne but what about the two NRVs? They DEF need to stay!
Looks to me as if the old olives for the compression fittings need removing and new ones fitting. Do agree completely about the FB ISOs
Have you tried tightening the individual components first, using two spanners or a pair of grips and spanners holding one to prevent spinning and the other to tighten?
Need to tighten the bottom but more
As you look at it needs turning to the right while holding the top hex on the same part / fitting not by hand need tools eg grips and adjustable spanner
Reply to How to fix leak after installing new kitchen tap in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a leak on my kitchen tap it is coming out off the bottom of the cold lever. How do I get the lever off? Also would this tap have a cartridge in the cold & hot or will it be just tap has had it & I need to get a new one?
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the radiators but still gave hot water to the shower and taps. Naturally we thought there was a fault with the boiler. We had already arranged a yearly...
Hi, as you can see pictured I have a stopcock without a packing gland. Over the past few days my cistern inlet was suffering from an airlock and it was hammering constantly after filling. I turned off this stopcock, drained all the pipes, turned the taps back off and then let the water back...
Hi I've recently had a new bathroom installed. I've noticed when I flush the downstairs loo there was a hammer type noise under the bathroom floor when the cold feed for the loo turned off/ same with the washing machine. So I turned off the mains water supply. Opened the highest tap first...
    • Winner
Hi all, I joined today and am a newbie at plumbing DIY. Thought I'd share my experience replacing the stopcock under my sink. The old one looked very corroded around the tap handle. An Anglian Water engineer was at the property measuring my water pressure and flow rate. When he saw the...
