Discuss How to dismantle tap, kitchen mixer, ceramic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I need to stop the dripping from the cold side of the unit. The tap goes from full on to off in half a turn so I assume it has a ceramic valve. Normally you prise the cap off, however there seems no gap at all and a knife will not locate a gap. Here is a photo
https://photos.app.goo.gl/Nvq4t8nJaSZqe8rf7
Next I tried unscrewing the lever handle and the double ended threaded rod that fixes it into the moving part of the tap. Photo
https://photos.app.goo.gl/tGvmgZEK3fbkRp4C6
Then I tried easing off the moving part of the tap, hoping that the threaded rod that was removed was securing it. Photo
https://photos.app.goo.gl/ULeYC1dTr9TQTxX68
That didn't work either. Can anybody help me get this tap dismantled? Thanks
Possibly inside or under here?
In your first photo you are trying to prise off an end cap. There is an inner circle below where you are trying, I’m pretty sure there will be a screw under that - try using a brand new Stanley knife blade.
Further to the saga, I did find an Allen key that fitted but the screw was stiff and graunchy but it did come off. I replaced the O-ring seal and had the graunchy hole retapped at the local engineering works.
But it still leaks. I now realise that it leaks from the body of the valve rather than the seal with the main tap.
szuCkVBTwL_TU6HbNbXUJI5iJGezQpO6im25gQ_0g4LI-Ds9aFd4D_SXkDO8lO8sUwgusmOaEAoxIPyktmk2CXAf9aB9Pyri1E4BDNBsGpVMAbPHJhEEGfwRFEr-F7tIf97Q7oxus0P2djKgTKqPSbRJdiCX13WRfXu5v8QamsVc3_soV3yfkFk7dBh1TfSQFlbbiLeY7Mvf0Pgc9qf8Tt4522Tl6WTsh791wB6xpzbNVhsrUanrU_RE0WEX_ZImGU_9n3Hue5_Fm6YOWPwuEuWedoOHE1egTkjq-zVFh9VwVR2AJ_LXzUhs-NvrnawPxQ7pxzIMIxd1f2dfnL-G93k26lI8FjMYrtmQCFOarOcoBnGHEVtM0cDixH4At_3mntkFXMrS59CG1NBlpsGW8iVIh4sXCz0fo1aP0fKoXS4d8emHMuAzVQ-M9QNJiwVJROLr0o3rSy8XmisekecCpt6lMCFOMVKaNXdwAnJNpdfa8tpV74zSSaLO8_aoVNLjyHDwXbfXjyE7-k9ipfDdrepxZDAG2Orxhdk06-uE0cZMkTvmtSJWXDxIymrSPR7eHZfnMtsGYV4jnSoNrFrq15n-D18YPsKT1ggy3QN7q_ZLaAfTN1uvmtHmgSdui9rUZtdBv805_tL0k0Les46Z1ArZesaxxO5yiWMz2ehJ02_885_9qvMNUaLAx9d3e-nrzBaSzbt4KoxMazuE_G8gCtq8fA=w1985-h1490-no
The local shop sells ceramic tap inserts but the splines are a different pitch
o_1ax-oxpaX1vj8GuQ9LT37tfsSPnVo0VRAWi-JIe-8662Q66kLWEZvx21DdsWtObnv3Zlna_WecXKxA7wCDcW_sdMXyEAo8OaFhsOlr_mW5ldKDzdqu4shlx37e9C40ch1tbwrT006AMGplfJ9GElIXbqhaOwjyr3afuqa-F3C92vWp5Yx55sMLh7d0TIjE5lY1kp6evWVtE-SyKMSaChWdg2HnVLgeUfJxUi8wB7YA91soN25IEO3F7QYcGdlxWFjYYI3iHbyBd_w7C_-2FphO-VUikmnqPsgcSucMLdf8F9GCyIzTJkDWJklfr5vMyw1h2zDoA6PrTXCDxzuAvdzZusRHBiVJsjGQ-BTwLq_kLkAB6NmJEyQq51EXFrUGo8exRapW1WDAXipDmElySVTRF3MA3TM2hYHehDq9iyVBycn2-d4C3hWAqxLW1jTB59vSelZZze3ttd5rdJkHbBGoxmriNow-Rap0sMIXVT3vOaitbV9ORvoXAzjgI2ugfHrgVGzFBbnJEbTUH16C6XJ4e_GKf3ecFZfgbIe4BTD-QIqtv3zmWivuDL6pDIFiZ3-VoEZfQH8iLqrLY0JY_dt7pacXmEr07ZmP6EwGJM2DHbODgOmE1CLB-oOMyo2D7GsEPNDpZnk9LfOFwB8qd7rOYd99rRHONfDmb4NyL_7A-9fM02t-jssFP0CUZRdudaIVnK7kRoQnHdSJXTwdYADDWA=w1985-h1490-no
So I am uncertain what to do.
Yours looks like a 28 spline.
Make sure you measure the seat depth properly from the underside of the shoulder to the very end of the red seal. That is VITAL.
Try the LUNNS website.
Reply to How to dismantle tap, kitchen mixer, ceramic in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
