Discuss How to disconnect Randall Danfoss SET5 programmer from backplate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A
andymcm
My Randall SET5 programmer is playing up - seems like a loose connection, as it sometimes flickers on and off.
I'd like to check the connections but I can't work out how to disconnect the main body of the unit from the backplate, to get access to the wiring. There are no screws at all (unlike more recent models), just a plastic tab at the top that can be pushed in, but doesn't seem to do anything.
Any ideas?
Any ideas?
There should be tiny grub screws in the top or bottom, if not the plastic tab you speak of you should be able to push it in with a small electrical screwdriver, whilst doing that you should be able to pull it off. Go easy!
Thanks, just got it off through a combination of raising the tab with a screwdriver and a reasonable amount of force pulling out the top of the unit.
Cheers
Andy
Reply to How to disconnect Randall Danfoss SET5 programmer from backplate? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
Hi there, I've a Danfoss Randal set2 to replace next week, I'm simply looking to obtain the installation manual for the old timeclock, I...
Hi guys, I have a fault on a clients heating system whereby the heating will stay on regardless of what the programmer is doing on its timed...
2K
I have an issue with the faucet (Franke Atlas Neo Sensor) and it will require it to be sent back to the manufacturer. However I have an issue with...
2K
Can anyone help, please? I'm looking for a heating system circulation pump for a domestic install, with 3 speeds, where the speed can be toggled...
