Discuss How do I remove the handle from a Bristan Colonial Thermostatic Shower. in the USA area at PlumbersForums.net
GTC
I have unscrewed the handle and removed the grub screw underneath but can not remove the outer body! The instructions say it should just pull off? TIA
That’s correct, although probably a misuse of the word “just”.
Try all the usual ; wd40, tap with hammer via wooden block, pour boiling water over, drive in wooden wedges etc etc - sometimes it is just not possible to get off undamaged - especially if in a hard water area.
Have on occasion had to cut off handle and buy a replacement, but usually only with a tiled in valve that cannot be easily replaced and no tiles available
Managed to get it off. Thank you for your advise!
Reply to How do I remove the handle from a Bristan Colonial Thermostatic Shower. in the USA area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes...
I have attached an image of the brass body within a tap. Having replaced a cartridge which has cured a leaking tap, I can see that there is a...
