Discuss hot water won't turn off in the Central Heating Forum area at PlumbersForums.net
No the light had gone off tooWas the green light on the receiver?
The hot water one stays open with the system off and it keeps the boiler goingAre both port valves closed eg shut ?
Have 240v And it’s been wired the same as before the fault. this is why it’s been driving me mad lolWired wrong or prog faulty do you have 240v on the brown to the hot water valve ?
Yes all offProgramer sticking needs changing if you remove it from the base plate you should loose your 240v on the brown hot water
I’m guessing the programmer is set to all off ?
Reply to hot water won't turn off in the Central Heating Forum area at PlumbersForums.net
