Discuss Hot water flow from Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Rickthelandlord
Having problems with a Baxi 105 he. It's been installed for seven years now and serviced annually. At the moment the hot water will only fire up if the hot water tap is opened fully and then it is taking a while to get hot, anyone any suggestions. I'm a landlord and not a plumber but would welcome some good advice before I call out anyone, thanks.
I think your engineer should be looking at the flow sensor, or a scaled plate heat if flow rate is down.
Thanks for the reply.
Reply to Hot water flow from Baxi 105he in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello All, I wonder if you can help me? I have intermittent hot water low flow from all taps in my 4 bedroom house upstairs and downstairs. I...
Looking for any ideas to help. I've a Heatrae Sadia Hot Water tank, heated through Oil fired boiler (working fine). A week ago I reset the air...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering...
Hoping someone can please help. I have an intermittent fault with my electric hot water. I have an older style electric hot water service that...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the...
