Discuss Hot Water but no Central Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Martin Stevens
I have a Britony Chaffateax and Maury Combi Bolier.
I have hot water when I turn the hot water tap on ( gas lights up)
Central heating is on a dial timer on the front of the boiler.
4 times over the past week the central heating has not turned on with the timer. Set the heating to "always on" and don't get heating to the radiators. Felt the incoming and outgoing pipes and they feel hot to the touch, as if the boiler is heating water but it is not getting pumped.
Is it likely to be the pump ?
Reply to Hot Water but no Central Heating in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and...
losing pressure
L
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
When I put the central heating on the hot water gets drawn through the pump but is then being diverted straight back to the boiler instead of the...
