Discuss hot and cold water issues!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
march
hi, got sent to a job today at a nursing home where they reported no cold water in kitchen. after some investigation i found that there was a trickle of hot water coming from the cold taps and this was the same in about 7 or 8 other rooms.
most of the taps have mixing valves fitted and i found one that had gone so replaced that but problem was still present. the cold is tank fed so i checked the cold water tank and it wasnt hot or anything and i cracked the outlet valve and water is flowing nicely so thinking theres a blockage on cold water pipework somewhere between tank outlet and the kitchen??
also as theres hot water trickling out of the cold taps im guessing theres another blending valve thats crossing over.
anyone else have any thoughts on this and are the lack of cold water flow and the hot water coming out of cold taps linked or is it a coincidence???
they have filters in, check the filters are not blocked
cold could be hot if it has a secondary return and is next to cold pipe
its definitely not heat transfer as the water is coming out at about 50 degrees
Reply to hot and cold water issues!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Got intermittent hot water coming the from a combi boiler to kitchen mixer tap when it hits the T junction for the upstairs bath it's hot, but on...
Hi, I’m having issues with cold water to multiple outlets. Taps, showers, toilets cold water is fine at the kitchen sink. The hot water system is...
2K
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Hi everyone, I turned my cold water feed off in the airing cupboard which supplies only cold water to my bathroom but it also turned the water to...
Hi everyone, Is this set up correct: Attic stop valve turns off the cold water to my bathroom (I think it is the rising main in the attic which...
