Discuss Honeywell bypass valve possibly not well in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After x number of years, I looked at this valve as the water was very hot very quickly through the valves.
It was set to the white band which didn't look correct.
I unscrewed the screw to reset it. It fell out and revealed three loose parts
Screw, red cover, and black part with the numbers on.
There doesn't seem to be a marker where the bits should go and if I fit it in place where the top meets the black part on the valve, the screw does not match the hole
The spindle of the bronze does not turn easily (not risking it).
Can anyone confirm that it is broken or suggest a fix that does not involve replacing the complete valve?
Thanks in advance
If it’s been doing it’s job for x amount of years things get warn / scale on them so if you can replace for best practices
Reply to Honeywell bypass valve possibly not well in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Just moved into a house and in process of renewing sealant around the shower cubicle. Feel free to skip to the bottom to get the question...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
My friend's bathroom is on a concrete slab. Near the shower there, for years, the wood has slowly rotted. Several folks replaced drywall, but...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
So, got a lot of water leaking from my boiler. (Old Worcester 28CDI) Looking underneath it appears to be from the isolation valve (at the point...
2K
