Discuss Honeywell bypass valve on suprima in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just been updating a heating system which previously had a gatevalve as a bypass with a honeywell automatic bypass -
I cant seem to find any instructions anywhere for the suprima 50 -
To set the valve it needs the minimum flow rate for the boiler?
Can anyone help? The pump being used is a 15/60 -
The valve comes factory set - have people found that works ok in most cases?
Btw is it an S or a y plan? I dont bother putting a bypass on a y plan.
Thanks - no it was for a s plan -
I have done some calcs incase anyone else comes across this -
If we assume the pump is a 15/50 and a suprima (9 litres min flow ) used and on pump speed 3 then the bypass needs to be set to 0.35bar
if the same but a 15/60 pump is used then it willl be set to 0.45bar
Do you have any reference to this?
Not easily. I worked it out by plotting the data on the 15/50 pump chart and the DU144 valve chart.
9 litre/min = 0.15 litres/sec = 540 litres/hr =540kg/hr
Reply to Honeywell bypass valve on suprima in the Plumbing Jobs | The Job-board area at PlumbersForums.net
