Discuss Hi Folks Newbie here with a PRV question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
coyote
I have a combined underfloor heating and radiator system (rads upstairs and towel rails) It seams my towel rails that are downstairs have two pressure relief valves on them whilst the ones upstairs do not. The boiler is downstairs and teh hotwater tank upstairs. It is a 3 bar system but the downstairs PRV's seam to relive regularly especially when i turn one of them off...any ideas why this would happen or if i can replace wonky PRV with a normal valve
cheers
C
Hi. Pressure reducing valve are not normally associated with the heating side of a heating/plumbing system. Are you sure this is the case?
Do you mean TRV (thermostatic radiator valve)? It will definitely not be a PRV (pressure reducing valve).
Post a pic if you can.
I wonder if they are Aladin auto air vents? should be marked up let us know please:)regards turnpin
I have attached some photos of the pesky valves
Just a draincock mate. It's for drainIng the rad or most of the system of water
they are just draincocks, they might just need tightening up or the washers may need replacing :D
Reply to Hi Folks Newbie here with a PRV question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
