Discuss Help fitting conceal cistern comfort level wc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bowtrees
HI I need help with fitting a standard cistern to a comfort level toilet
in a 770 vanity unit .
Tried cutting the pipe but still not enough fall.
Cistern is high to top of VU but cant get the lid on unit and flow on fall is
leaking with the pipe cut!
I need a low level cistern but cant find one ( mine is 275mm on box height)
i need smaller and ideas. Thanks
i think you need a higher cabinet with a comfort height pan to get the conc cist at the correct height
HiSteve,
i think your right i need an 850mm High toilet vanity i cant seem to find one of these either !
Not having much luck as just cut the unit today so that double costs !!
I dont know why no one manufactures a smaller cistern,
i have tried Germany, Usa, all uk manufactuers with No Luck.
Thanks anyway, have a good weekend H:christmastree1:
Not sure you'll get a smaller cistern as these will need to be at least 6l and they will be as small as they can be to be concealed in the first place
When you have cut the flush pipe to fit the cistern there really isnt much left , by the time its inserted, it virtualy bends straight away .
Hi
they should make it rectangle shape instead of a cube shape
it would still be 6lt. Just in different shape and we could have more options.
thanks H
Reply to Help fitting conceal cistern comfort level wc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
