Discuss Height of new boiler .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Murdoch
Res.Electrician
Chaps,
I'm a spark and working on a refit ..... the GSE is going to put the new boiler on the wall very close to the floor - is this OK?
Never seen one low on a floor before.
If it's to M.I's then it's ok. Going to be a right tw@t to work on in future though, accessing valves etc. Sounds like he's a F.I.F.O merchant!
Normally most require 4-6" below the boiler
Any reason why he's fitted it so low ?
Can't be under a window, unless he can achieve the correct clearance.
^^ it’s going in on Friday ..... when I’m back onsite I will take some snaps and post them
Reply to Height of new boiler .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes sunk into wall behind bath. Walls have fresh tiles. Have realised as about to fit shower these pipes one is set higher than the other. If you fit a...
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
