Discuss heating doesnt get to max temp then cuts out...help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Mobileghod
the boiler works fine until the heating gets to a tempertaure then cuts out. its not the max temperature they are used to?
any ideas where o start looking
thanks
Do you mean that the air temperature in the house doesn't get hot enough or that the water in the radiators doesn't get hot enough? Does the hot water in the cylinder get hot enough for a bath? Any idea on the boiler?
boiler is a glowworm he says that the boiler runs the heating when switched on at the programmer then after 10 mins it kicks out again the he has to keep resetting it!?!?!
you reckon i need to drain down flush out and get all the air out of the system again?
Reply to heating doesnt get to max temp then cuts out...help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Heating and hot water is not working. Plenty of heating oil. I have replaced batteries in thermostat and it seems to be working ok, showing flame...
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
Hi I have recently bought a house which is 17 years old. There was a small leak from one of the radiators So I took the pipe off and drained the...
