Discuss heat sink rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
lenny
Good evening,
Can anybody advise me, What is the a maximum distance a heat leak radiator can be horizontally from the primary flow and return on a semi gravity system? The primary flow and return is in 28mm and the pipe work to the heat sink radiator is in 22mm.
its not that simple lenny. post a drawing, lots of other factors to be aware of as well,
such as fuel type, boiler size, total system kw, gravity, fully pumped etc
Hi Shaun
Thanks for the reply , I have posted some drawings with another new thread ....
Lenny
Reply to heat sink rad in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
  • Sticky
