- Messages
- 272
As an approx percentage, how much less heat would a single panel non-finned rad give compared to one the same size with convecting fins?
Many thanks.
Many thanks.
Discuss Heat Output Difference Between Finned/Unfinned Rads? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
It depends on what you are comparing.
To compare modern rads - look up the difference between a P1 and a K1 on [DLMURL="http://ukweb.stelrad.com/uk/resources/files/b9f4facf41064b974ee7dc716fd5ca26/elite.pdf"]this stelrad list[/DLMURL] Its a bigger difference than you would think.
Historically, this would be less. Originally, the fins were welded to the gaps between the waterways. When they shifted to welding them directly to the waterways, the output increased massively - IIRC it was about 15%.
Yes. You can get them with or without bags.
This finned advantage may drop off with time ( 100s of dam spiders this year )
Is there a purpose made tool cleaning tool ?
Reply to Heat Output Difference Between Finned/Unfinned Rads? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
