Discuss Heat only,boiler recommendations? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pssst
Considering replacing my spacesaver..only need about 12 Kw or thereabouts.. ta
viessmann or intergas
Reply to Heat only,boiler recommendations? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, Looking for a recommendation for a heat only boiler to replace my 30yrs old ideal boiler. Any makes you would recommend and any to avoid...
I've got a non condensing Glowworm Ultimate with gravity tank and hot Water tank in a 4 bed house. 11 radiators 1 double 1400mm length 1 P+...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hello, I have a gas boiler in my apartment that heats a net area of 300 m2 with an underfloor heating system. The boiler has a capacity of 45 kW...
