Discuss Heat only,boiler recommendations? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Pssst
Considering replacing my spacesaver..only need about 12 Kw or thereabouts.. ta
viessmann or intergas
Reply to Heat only,boiler recommendations? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have an ideal vogue max S18 boiler and I’m considering fitting auto balancing TRVs, my question relates to the boilers pump. I see a boiler...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath...
Can anyone recommend a decent multi meter, preferably under a 100 pounds. It's for checking boiler components so I don't need a top spec one...
