- Messages
- 34,368
- Solutions
- 2
Fill the boiler up to 1 bar once the cylinder has stopped draining does the cylinder start running with water
Discuss Has my hot water cylinder coil broke? in the Central Heating Forum area at PlumbersForums.net
Thanks.Fill the boiler up to 1 bar once the cylinder has stopped draining does the cylinder start running with water
Here you go. ThanksHave you got a pic ?
Open a hot water tap to allow air in and help drain the pipework. (The glugging sound on the video is the clue that this is needed.)Currently the cyclinder is still running at a slow pace into the washing up bowl which I keep emptying.
Ive had the nearest hot tap open througout the drainningOpen a hot water tap to allow air in and help drain the pipework. (The glugging sound on the video is the clue that this is needed.)
Ive tried tried to do this. Went abit past 1 bar, but in using the filling loop water was coming into the tank anyway and yess it did drain down (hot water tap was open not sure if it was meant to be)Fill the boiler up to 1 bar once the cylinder has stopped draining does the cylinder start running with water
yes, as above. Ive tried tried to do this. I did go a bit past 1 bar in filling back, but in my configuration, opening the filling loop and the col water valve (on the picture I put that you asked for) water is also going into the empty tank at the same TimE (not sure that is what you intended.So you filled the ch sys to 1 bar then opened / left open the cylinder drain and water came out and the boiler pressure went down ?
Reply to Has my hot water cylinder coil broke? in the Central Heating Forum area at PlumbersForums.net
