Discuss Guys who do electrics... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
Got a light switch in me gaff that doesn't always turn on. Some times needs bashing a few times (which I perform using a thick rubber soled trainer rather than my finger.
a) Am I likely to be electrocuted at some point
b) Is my house going to blow up / catch fire unless sorted asap
c) what is likely cause / solution
Answers
A. Yes
B. Yes
C. GET MISSUS TO HIT IT
ON A SERIOUS NOTE GET A NEW ONE MATE<<<<
you can get a switch and change from a quid.
of course it could just be a loose connection which would cost nothing to fix.
is its two way switching? be sure to put everything back as is.
and of course isolate the power first.
whatever way you go about it use a multimeter to make sure its isolated,light switch easy to replace
Reply to Guys who do electrics... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Context for issue: I'd like to start by saying I'd rather not read 100 "Hire a professional comments", I will do that when/if it comes to it, but...
Butchy10
B
Context for issue: Last winter the temperature switch on my boiler shorted somehow, the boiler was then running WAY too hot and ended up...
In our Village Hall we have a Ideal Concord CXS/SD40/H central heating boiler. This was installed new when we had an extension built and the...
Hi everyone, I'm looking for some advice please. My system has 5 Drayton Wiser TRVs. There are 8 rads over 3 storeys and a 170l unvented...
2K
5K
