Discuss Grundfos noisy oil central heating in the Central Heating Forum area at PlumbersForums.net
Hi. We have a wolf oil central heating system, with a grundflos alpha 2 circulation pump. Sometimes it makes a tinkle noise ( like metal to metal) and sometimes not. With and without burner running. I removed pump and impeller is ok and clean. Bled system through. Nothing helps.
Would expect a bit more than that, maybe worth looking at the settings and power W and m3/hr, if something like this one.
Reply to Grundfos noisy oil central heating in the Central Heating Forum area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
