Discuss Grout stuck in pan!! Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Fallon1982
Morning chaps
Currently finishing up a bathroom refurb for the customer from hell. Everything going perfectly well up until this morning when I noticed there is grout stuck inside the pan!
anyone know how I can get this out without damaging the bowl?
thanks in advance
Carefully?
Is it a blob or a layer in the bottom? I'd probably carefully chip away with a flat screwdriver constantly wetting the grout to try and soften it then use my finger nail to get the last bits.
If you don't already have one, get a bath rubber in case you catch the China slightly.
Morning chaps
thanks in advance
Hello there,
First question is , how comes grout is in the toilet ? Why would you skip the dirty water in the toilet ?
I would keep it wet too as mentioned above and keep knocking it away. Maybe undo the toilet and see how the outlet looks like you may need to do it from both sites.
I tipped a bucket of dirty water down there last night and forgot to flush it through. It was only residue from cleaning tiles off but it's gone rock solid now.
I never do this! Always tip it down the drain outside or in the old pan!
So annoyed with myself . Got it soaking in bleach now.
Yeah happened to me as few years ago and I had to replace the toilet from my own pocket grrrr
But that's the way I learned :) fingers are crossed you will get rid of the grout.
Is there a lot in the pan? Don't make any scratching stains mate
Just put some clean grout down there to camouflage it, get paid & get home, block that number :p
Wouldn`t use a screwdriver myself as one slip and bowl will be scratched or worse, instead a piece of hard wood and cut the end to make a chisel point then break away the edges and work inwards.
I'd try a brand new sharp thin chisel and then tick-tick it away with the same care as if I was on an archeological dig.
Should never pour grout down any drain, inside or outside. It will settle in any trap or pipe. Bucket shoud be scraped out completey, then anything left, rinsed and cleaned out into a skip or bag.
you daft cockwomble................ won't be doing that again, will you? never pour any cement, plaster or other such crud down anyones drains but your own, paying to have a set of drains cleaned, excavated and relaid can work out a tadge costly....
Small steamer with a hand held nozzle will work, not sure about the heat on the ceramics though?
All these suggestions remind me of the saying 'If there are a hundred solutions to a problem (i.e. hangover: hair of the dog, drinking raw eggs, glasses of water between pints) none of them work' but if a problem has a known solution that works (headache: paracetemol) you can tell because there is no other solution offered/needed.
If you can get the pan out easily take it outside and pressure wash it......regards Turnpin:biggrin:
Reply to Grout stuck in pan!! Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am desperate for some help. Basically we are having our bathroom renovated. The plumber removed the units, including the sink a few days...
Deleted member 120897
Hello. This is my first ever post asking for help. I had a bathroom renovation done early this year which I did myself. I wanted to have a low...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
I'm trying to pull a Polypipe SA62B access plug and cap out of the soil vent branch (which I think is a Floplast SP190). It's a bit of a cramped...
2K
