Discuss Greenstar 24i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Christopher Powell
Hi all can someone help me out. How exactly do I check the resistance on the solenoids of the gas valve I can't get my multimeter anywhere near the connections
Thanks in advance
Worcester used to do a test card for this purpose (pub end testing)
If the solenoids are at the back it’s probably the old style valve!
I’d connect up my u-gauge to the gas inlet, if the pressure doesn’t drop on ignition (when power applied to gas valve) then it’ll be the valve!
Sometimes you’ll see cracks on the solenoids, this can be a sign it’s given up! You’ll need a torch & flexi mirror...
Changed valve problem solved. You were spot on, cracks on both solenoids
Reply to Greenstar 24i junior in the Plumbing Jobs | The Job-board area at PlumbersForums.net
