Discuss glued waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
I done a first fix few weeks ago where i know i glued all the fittings as before i left i poured water down them and gave the waste fittings a good heave ho and nothing come apart ,,,not a big waste run either so was not alot to check.
had a phone call to say waste has come apart gone back and an upright is total out the fitting but i defo remember gluing that part because remember giving the upright a wobble to see if any thing moved abnd recall it all being rigid , i dont remember any dirt being in fitting from memory nor as i said being loose but defo sure i glued it.
wondering if the glue or fitting could have been duff or if anyone has had something similar before ??or if anyone has had chippie clout a pipe and yet not break it but fitting popped out??
No i never used cleaner before anyone asks but done millions glued joints and never had issue ,
Are you sure it was solvent weld pipe you used not a push fit pipe, normally different slightly different in size but I have seen it done before now!
You're not supposed to put water into solvent pipework until next working day. Depending on what fittings and glue you've used, it should tell you how long to leave the glue to set before testing/first use on the label on the tin.
Most likely glue had not sufficient time to fully set properly.
The only way Ive found to separate solvent fittings is to use heat.
Blame the chippie.:ihih:
Anyone trying to glue pushfit pipe into a solvent weld fitting shouldn't be calling themselves a plumber.
You can tell if it's been glued as there will be residue on pipe/fitting. I've never known one to come apart once glued unless it's been really clouted but then it tends to smash.
100% certain solvent weld picked it up same time as fittings from plumb base , it was about 7 hours later poured water down it never ever had issue before and never had one come apart after being glued so totally perplexed by this .
mate, you've got to admit, if it came apart you never glued it
solvent weld can be pretty tight when you put it together unglued
so you might have mis-judged it.
Blame absolute everyone ...
The joiner hit it when doin the floor
The dog must of bit it off??? (Put teeth marks in pipe)
EVERYONE but you! :p
Blame the glue manufacturers......was a dodgy batch of glue.
Blame the kids for sniffing it and the manufacturers taking all the good stuff out!
It happens, it did to me once on a Saniflo (oops !) Took about a week before it blew apart. Had to eat a bit of humble pie, fixed it and bought the customer a nice bottle of wine, been back since for other jobs.
It is easy to do, especially at the end of a long day when you are on your back under a bath thinking about the cold one in the fridge at home.
All part of life's rich pageant
Sent from my iPad using Tapatalk HD
turned out it had been glued could feel it in fitting and on pipe ,,,,baffled how it come off tho maybe dirt .
I have never had a glued fitting come apart, they are normally impossible to pull apart after about 2 minutes of putting the glue on the pipe.
Agreed.
Which brand glue did you use?
only time ive seen this is when the fitting was not glued correctly. either down to grease or glue not applied correctly. Solvent overflow pipe does come apart alot easier, especially when other trades decide to boot the crud out of it.
Reply to glued waste in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey everyone, I have a Duravit vanity unit and was recommended to buy the Duravit space saving waste: 005076 But im unsure how this connects...
Hi Everyone, Can anyone help? I have been searching but with no luck. I am trying to fit a Duravit shower trap which has a 50mm outside...
1K
I had a shower waste today which was supplied with the tray and wouldn't tighten up, just kept slipping threads. I've had a few of these before...
Hi I'm currently doing the pre-planning for my next DIY project fitting a shower tray and enclosure from scratch. I'm confident of being able to...
Afternoon, our bath waste pipe in our rented property has started leaking slightly when we shower. We've narrowed it down to a loose screw in the...
