Discuss General question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Good Day everyone,
Not sure if this is the right place to post.
I live in an apartment, there are two apartments on this compound.
Two tanks, one for each of us.
However, our tank always runs dry and the neighbor's own is always full.
Any idea what might be causing this?
Are these pics fine ?
are you sure yours is just connected to your property and not your neighbors as well?
Where’s the hose fed from eg supply the tank ??
The hose I'm gonna use is connected to the neighbor's tank
So I was just going to use that to fill my tank.
They're allowing me, because I think we figured out that their tank is taking my water somehow
Do you have any access holes / panels in the top ?
That's going to be a very time-consuming process. I think you will soon want to get a plumber to fix the pipework so that each tank feeds the correct dwelling. It should be a relatively quick and easy job for someone who knows what they are doing.
Reply to General question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
Hello everyone, I'm facing a rather complex situation and I need your expert advice. My neighbor and I share a boiler for hot water, and we have...
Hi all, grateful for your expertise on the following. DIYer, not pro. Rural property in France Single storey. Septic tank. Late 80s construction...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
