Discuss Gas portfolio (services required) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I’m looking for a gas engineer to do 5 boiler services with in or near luton.
The main things I need are pictures and the gas rate and analyser readings.
I would appreciate if anyone could help out thanks.
Think you’ll need to sell yourself a little mate. What experience have you got? What can you offer someone that’s going to help you?? You have to see that by doing this they are ultimately training a competitor
I have been in the same situation as you and came across lot of expensive and unreliable engineers but luckily i found couch Tony Morgan *** advertising gone*** check it out.
Bit of shameless advertising there with your first post. Please at least say hello first. I’m assuming you work for them as youre dragging up old threads
Reply to Gas portfolio (services required) in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
