Discuss Gas flow for new fire. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
roythegrass
We wish to have a glass fronted hearth gas fire installed. Other than the heat output an important factor is the visual appearance – flame height, spread etc. Our existing gas supply pipe exiting the concrete floor is 15mm OD. One dealer assures us this is adequate. However another dealer says it should be 22mm as when the gas central heating switches on it could cause the flame height in the fire to diminish and, having experienced this with previous installations, they declined to quote.
In response to an email to the manufacturer they state “The exact diameter for the gas supply has to be calculated based on the length of the gas supply, how many other appliances that are connected on the supply and the maximum gas rate.” They did not say what the gas flow rate and/or pressure should be at the junction of the supply pipe and the appliance. Further the dealer says this cannot be established until the appliance is connected (by which time it’s been paid for and installed!)
Is there a means of measuring the gas flow rate at the point where in appliance is to be installed to first establish that it is sufficient?
Thanks in advance.
Agreed. Find a gas man you trust and get him to work it out for you. He'll install and stand over it.
Job 38.11
Reply to Gas flow for new fire. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So we are looking at a new vaillant ecofit pure 418 regular boiler but have a question about the gas pipe size requirements.. At the gas meter...
4K
    • Agree
A I correct in saying that when you install a new gas appliance in a rented house. There is no need to write out a CP12 and test all the other...
Hi all, Just had a Navien NCB 40kw combi installed by an approved fitter. The DHW rates of the boiler seemed promising on paper - 16.4lpm at a 35...
9K
Hi all, Firstly i feel really dumb asking such a amateurish question so please be nice as i feel i have to ask for clarification i'm working...
