Discuss Gas cooker/Hob pressure testing and fitting questions. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cmarkr
Hi all, relatively new to the gas industry about a year and normally just do fires and boilers.
The only reason i have the cookers ticket is for lgsc's. I am fitting my first freestanding cooker tomorrow and i have a few questions which may sound dumb.
1. Is changing all the injectors (converting NG to LPG)much the same as a gas fire/old boiler injector take them all out and just do them back up tight with no ptfe or compound on?
2. This particular cooker has some strange 1/2" male on it rather than the traditional female thread. Can i just use one of these (https://www.bes.co.uk/1-2in-equal-socket-female-x-female-malleable-iron-galvanised-8089) with ptfe both sides, just seems a bit rubbish?
3. When testing working pressure on NG i normally have the three or four largest rings burning with the manometer hose held onto the smallest injector with the gas tap pushed in which should give me my working pressure. I assume i'm doing this bit right as that's all i ever saw during my apprenticeship.
But when doing the same with the last two LPG cookers i've lgsc the pressure dosn't rise correctly and when i remove the manometer hose a flame flys out of the small injector when removing the hose as if its ignited in the metal connecting pipe and back fed through that injector taking my arm hair off.... Have i just been really unlucky or am i doing something completely wrong here and being a muppet?
4. How much are GSRI like you fellow gentleman are actually giving a massive concern about gas pressures on cookers. As it seems every one i ever go to is under-gased like as if its general conception to just bang it in regardless as long as the flame pictures correct its good enough...??
Thanks in advance
is it a loose nut ?
Bes 23257
Yeah popped in my local city plumbing and they had one of them its exactly what i used.... Thanks. All in and fitted.
Questions 1 & 2 answered but could do with some opinions on 3 &4.
Tried checking working pressure same way i described and the same thing happened had a flame fly out again, if anyone else could chime in if i'm doing anything wrong it'd be great.
what do you mean doesnt rise correctly ?
depends how far out tbh as its an unreg appliance you need it spot on or within limits i would gas rate it first before doing anything else aslong as the flame pic is ok
Sometimes when i do it it'll only rise to like 20mbar, today only 5mbar (when clearly the pipesizing looks correct). Then when removing the hose from being wedged down on the injector you get this flame fly out. Ive never had this issue with NG though. which is why i'm questioning why it keeps happening to me.
When its NG its easy to confirm with a gas rate if you can't see pipe sizing. But on LPG what do you do, other than a visual if i keep experiencing these issues. The one today i wasn't worried about as i fitted everything changeover, pipework etc...
was that on the small burner?
i would say there was some sort of restrictor to prevent flame lift did you try the big burners?
On today's one no i didn't, as i have previously tried that on the last LPG rangemaster which i encounter this problem on and the same thing happened at a larger injector too. Is the way i'm carrying out the test in my first post seeming the standard procedure to you?
yes an acctable method best way would be to cut a test point into the line before the outlet / appliance
Cool thanks Shaun at least i know my procedure is correct. Yeah i will on everyone i fit from now on its just bloody easier. Probably give one off these ago as well to save trying to bodge the hose onto it push in the knob and balance a manometer....
Thanks for your help i appreciate it
Got a link for that?
Reply to Gas cooker/Hob pressure testing and fitting questions. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
    • Friendly
Hi, I've followed this excellent forum for several years but have never posted, so decided I'd better give some details. My status is the upper end of DIY and I've a couple of house renovations under my belt (my own homes) I am retired but do volunteer handyman jobs for the elderly. Not...
